CA_Traveler
Jul 05, 2014Explorer III
moondoggie2 wrote:IF it's a dirt problem this likely didn't help. Keep in mind that you have 2 or maybe 3 layers of the 5 radiators. It's not easy to get the between radiator sections cleaned.
RADIATOR HAS BEEN FLUSHED AND DIRT BLOWN OUT FROM THE OUTSIDE WITH COMPRESSED AIR RELIVING THE OUTSIDE DIRT.
The air is drawn in so blowing from the inside out could be more useful if using air helps at all. Much better to use repeated applications of simple green as suggested above.
The radiator could have internal blockage and would need to be removed and repaired/replaced.
38,777 PostsLatest Activity: May 24, 2026
