JetAonly
Jul 05, 2014Explorer
moondoggie2 wrote:
OVERHEATING ISSUES WITH MY MOTOR HOME
IT IS A MONACO POWERED BY A CUMMINS IT IS A SIDE RADIATOR MODEL
REPAIRS MADE TO IT SO FAR ARE AS FOLLOWS:
RADIATOR HAS BEEN FLUSHED AND DIRT BLOWN OUT FROM THE OUTSIDE WITH COMPRESSED AIR RELIVING THE OUTSIDE DIRT.
THERMOSTATS IN THE MOTOR HAVE BEEN REPLACED
WATER PUMP PRESSURE CHECK DONE.
HYDRAULIC LINES THAT COME FROM THE HYDRAULIC PUMP AND ATTACH TO THE HYDRAULIC RADIATOR FAN DRIVE HAVE HAD THE LIMITER VALVE REMOVED AND THE FAN RUNS AT A FAIRLY HIGH SPEED.
THERE IS A 50/50 MIX OF ANTIFREEZE.
THE RADIATOR FAN BLADES HAVE A ADJUSTMENT ON THE FAN AND YOU CAN ADJUST THE BLADE PITCH ALLOWING MORE "PULL" BUT THIS OPTION HAS NOT BEEN PREFORMED.
THIS HAS BEEN VERY FRUSTRATING AND I WOULD LIKE ANY ONES ADVISE
THANKS
You very likely have the same set up I do. Under what conditions does it overheat? Flat terrain at 70F? Pulling hill at 11000ft at 90F? What gear are you in when you overheat? What RPM do you operate the motor at? Are you towing?
