fleetwood07ExplorerOct 20, 2015Monico slidesOn a 2006 Monico 40' Windsor do I put the slides out first and then level or level and then put out the slides?
teddychampExplorerOct 20, 2015Slides are installed in the Factory with the Motorhome leveled. So it is always a good Idea to level before moving slides.
Related ContentAdding power outlets in slide with no wiringarctic fox slide adjustmentEasy way to remove slide topper?slide out 120v harness issues2000 Monico Diplomat fridge won’t run on propane
