-Gramps- wrote:
ArchHoagland wrote:
6. Learn where your ice maker shut of valve is located.
7. After you learn where your shutoff valve is, I suggest you replace the standard plastic tubing water supply line to your ice maker solenoid with a reinforced ice maker hose.
Excellent advice. My shut off was under the refrigerator in the cold air return for the furnace. Don't ask me how I know.
I suspect you learned the same way I learned where my shutoff is...after hearing a hissing sound.
Water was running out the side of the coach. Every RV trip is an adventure...
