dougrainer
Jul 04, 2013Nomad
No, that motor has an electric brake. Just use in release mode and the only time it needs to be "engaged" (locked) is when it is retracted. Check the wiring at the motor. You may have to cut off the rubber boot. "Some" of the models have 4 wires. 2 wires (large gauge) are for the motor and the other 2 wires (small gauge) are for the electric brake. These types require that the electric brake wires(small gauge wires) be connected to the same wires as the motor. Others, the wires are internal to the motor assbly. A 14 year old PG probably does not have the 4 wires externally. Doug
38,782 PostsLatest Activity: Sep 10, 2026
