sportech wrote:
Sorry, I don't have a pic. Essentially, I made it into a 3 point attachment to the coach frame. The two points on either side of the receiver bolted to the frame. A "U" shaped frame of 2x2x1/8" wall tube bolted to the main tube of the Versahaul carrier. It adds a lot of side loading support and also some vertical support. The "U" shaped frame is removable, along the the Versahauler.
Kidoo wrote:
sportech wrote:
I have a Versahaul VH-SPORT that is rated at #600. The hitch for towing (behind the motorcycle) was rated for only #3000 so I added bracing that attached to the motor home frame with 2, 2 1/4" square tubes (similar to a 2" hitch). I have towed my #3500 Fusion with no issues.
I would be very interested on how you braced the attachment to the motor home. Would you have some picture?
Thanks
Ok thanks, I will try to figure something out. I saw some that have 3 point attachment hitch but I do not know how to attach it to the frame, I will keep search the web.
