Kluckraft wrote:
I do have an exhaust brake which helps a lot,
Do you have a exhaust brake or a engine brake (Jacobs engine brake)? If you have a exhaust brake, you can upgrade to a
Pac PRXB exhaust brake. Its design delivers the strongest braking horsepower, greatest speed reductions and shortest stopping distances possible across the rpm range without the use of service brakes. But if you have a engine Jake brake, forget everything I just said, cause the engine brake is better.
But as others have said, it sounds like you have glazed your brake pads and need to learn how to stab brake. Overheating and riding your brakes will do nothing but end up getting you into trouble, and endangering those with and around you.
