DFord
Feb 20, 2020Explorer
BEFORE YOU DO ANYTHING ELSE TRY THIS!!!!
It's called the CHEAP HANDLING FIX or CHF for the Ford Chassis. All it requires is moving the sway bar links closer to the axle. Look at the existing link connection. The factory uses the outer holes farthest from the axle. Just move them to the inner set of holes. You should also change the bushing that hold the sway bar to urethane because the sway bar is going to being a lot more work after this change.
When I bought our present MH, it felt top heavy. I tried the CHF and I couldn't believe the difference it made. Some will say you need to replace the links with adjustable or longer links. I bought a set for the front and by the time I finished adjusting them, they were the same length as the originals.
