We had 3 fifth wheels before, the last being a 40' with full slides. I'm not sure we lost room with a MH, just different. We don't have as big a pantry or bedroom closet in the MH, but we have 2 bathrooms and enormous basement storage. I guess it's a trade off by individual floor plan.
With the 5th wheel, I hated the dually truck the most, and I really learned to despise the trailer chassis they are built on. If you can get away from the standard LCI I-beam frame and buggy springs most have and into a high end frame and suspension, you'll be steps ahead. However not many companies that build them anymore and the trucks required to pull them are back into the heavy duals or MDT range again. We did have an LP 5500 gen, but not a lot of situations you used it. It was something you needed when you needed it, but not really worth the cost.
For us, the MH is far more automatic (transparency of systems between roadboound-parked-camped) between the inverters, generators, autostart, etc. which makes it easier for us. As a result, we are more willing to move it or use it than we did the 5th wheel. It's also nice just to have something solid, or at least the perception is that it's much more solid and sturdy than the 5er.
