timmac
May 21, 2017Explorer
80 psi would be the safe bet and still have a soft ride, you can do the fronts at 75 psi but would not go below 80 in the back, if you tow a trailer with some hitch weight than 85 psi or more in back would be better.
I don't know why people say you need to weight 4 corners, just load RV even on all sides and just weight the front and back axels, that is all that is needed..
I call BS on weighting 4 corners, not needed unless your motorhome is leaning for some reason..
38,780 PostsLatest Activity: Mar 30, 2014
