jadatis
May 22, 2017Explorer
Filled in your weights in my made extra save pressure-calculator.
Gave for the maximum speed of tires , wich is most likely 75m/h, next advice.
Front 86 psi Rear 85 psi.
but also derated the tires for as if 99m/h was maximum speed, together with the 10% reserve adding for R/L inbalance, it gave next advice. Front 97 psi and Rear 95 psi.
This is the pressure I advice for maximum reserve with still acceptable comfort and gripp.
Did you have everything in the Motorhome when weighed, so also all the persons. Otherwise we would have to add some weight to the axles and calculate a new advice.
38,780 PostsLatest Activity: Mar 30, 2014
