tropical36
May 22, 2017Explorer II
kmb1966 wrote:
Could someone double check me on my air pressure? I could not find a weigh station to weigh all 4 corners, but I do have front and rear weights so far. Loaded the RV for travel.
Front: 6,540 lbs
Rear: 12,200 lbs
Total: 18,740 lbs
Tires are 245/70 19.5 14 Ply.
Hercules tire says maximum pressure 110 lbs. But they only show inflation table for 110 psi. Shows same carrying weights on the Single and Dual as the Goodyear G670 table.
I am putting 95 lbs on all 6 tires.
Don't worry about weighing all four corners, use any inflation chart for the same load range tire and then add 10 - 15psi to take care of all the variables you will encounter, from shifting weight to changes in ambient temp. and everything else, in between.
