drwwicks
May 23, 2017Explorer
timmac wrote:
80 psi would be the safe bet and still have a soft ride, you can do the fronts at 75 psi but would not go below 80 in the back, if you tow a trailer with some hitch weight than 85 psi or more in back would be better.
I don't know why people say you need to weight 4 corners, just load RV even on all sides and just weight the front and back axels, that is all that is needed..
I call BS on weighting 4 corners, not needed unless your motorhome is leaning for some reason..
If you don't know what the weights are you can't load correctly. Guessing is an amateurs way. Mine is about 800 heavier on the right side empty so if I want to balance the load I need to concentrate heavier things on the left. I'm not going to be able to get it perfect but now I know which side needs weight. Air suspension will adjust lateral ride if it's set correctly.
EDIT. When weighing you don't need to weigh both sides and the whole coach. Just weigh one side and the whole coach and do the math. Subtraction works wonders.
38,782 PostsLatest Activity: Sep 10, 2026
