4x4van
Jun 24, 2017Explorer III
blazenpm wrote:You are correct to not go with the pressure listed on the tire itself, but going instead with the RV's door tag is ONLY correct if the RV is at it's maximum allowable GAWRs and running the stock size/load range tires. Since the OP has in fact weighed his coach, the door tag is irrelevant.
Check your motorhome specs. I just learned not to go by what is printed on the tire, but what the motorhome manufacture recommends for your GVWR and the max wt. per front tires and rear tires. I was going to put 100 lbs. in mine then I looked on the manuf. recommendations and it was 75 lbs. for the front and 65 lbs. for the rear ( I have duel tires in the rear). This will potentially prolong the wear on your tires.
38,782 PostsLatest Activity: Sep 10, 2026
