rgatijnet1
Jul 30, 2015Explorer III
robatthelake wrote:
The Public scale operated by the Dept of Highways near Parksville ,BC has enough room along side to weigh the Left side Front and rear ,independently. Then we drive around and reweigh the entire Coach. It's simple to subtract the left from the total to come up with the independent weights.
We only go there when the Scale is closed to commercial traffic. The scale is actually turned on 24/7!
I'm pretty sure that Most ,Government run scales are set up the same way!
Unless the coach is perfectly level when you pull in off to the side of the scale, the weights given are not accurate.
38,782 PostsLatest Activity: Sep 10, 2026
