tropical36
Jul 30, 2015Explorer II
kmb1966 wrote:tropical36 wrote:kmb1966 wrote:
We brought our motorhome to have it weighed today. The scales in my area only weight the front and rear axle weights. So far no place to weigh all 4 corners. Here are the weights with water tank 3/4, Fuel 1/2 tank, mostly empty storage bins, 2 passengers when weighing. Propane full, empty holding tanks.
From the CAT Scale:
Front: 6,640 lbs (MAX 7,000 front axle)
Rear: 12,300 lbs (MAX 13,500 rear axle)
Total Weight today: 18,940 lbs (MAX 20,500)
I am using Hercules H-902 245/70 19.5 "G" rated tires with 100 PSI in each.
Tires states: 4540 Single 4300 Dual @ 110 PSI
Is my tire pressure correct? Too high?
Thank you in advance.
Hard to say without knowing what your chart says for 100psi, but does sound high for now.
I will say that if you're not going to weigh again and considering you're so close to max., I'd air up according to the GVWR axle ratings and add 15psi for a cushion to take care of the variables, including varying side to side weight differences.
Just curious, but what might be your GCWR rating
The GVWR is 20,500 lbs
The GCWR is 26,000 lbs
Well, even loaded, you still have plenty left for towing, so that's good. I'm guessing you have a Ford chassis with those numbers and the age of your coach.
