Executive45
Jul 31, 2015Explorer III
Your weights mean little unless you're locked and loaded for a trip. Food alone will set you back several hundred pounds. That said, you only have 1500 pounds to play with. Your coach should be loaded as you're ready to travel, full fuel and stocked pantry and fridge. You can have your fresh water 1/4 full and empty black/grey tanks. Once you're loaded and ready, then have the rig weighed. Good luck keeping it under your gross weight...you're pretty tight...Dennis
38,782 PostsLatest Activity: Sep 10, 2026
