skiwhiz
Feb 15, 2021Explorer
Mountain Driving
Purchased Cass A Traveller motor home Ford V10 Automatic. Would like hints for driving/barking in mountains, passes etc, all help and suggestions welcome ??????
valhalla360 wrote:ReneeG wrote:
I believe the gasser doesn't have the Tow Haul mode where you can tap the breaks and slow it down like diesels. When we had a V10 truck and towed a travel trailer, we had to do the slow lane with the semi's and slow it way down, then pump the brakes at the end to keep them from seizing up.
Our 2008 F250 V10 does and it works great. It would be shocking if a much newer MH doesn't.
I believe what you are thinking of is an exhaust brake. Since a diesel doesn't have a throttle to choke off, it gets very little engine braking effect. An exhaust brake has as similar effect but works by restricting the exhaust rather than the inlet. This is common on most newer diesels.
Worst case, if it doesn't, just manually downshift for a similar effect.
