upsidedown Charlie wrote:
I physically felt the 24 just now and it does have two coax inputs. Only one is connected in the house. I'll check the one on the MH when the tech arrives.
Look at the manual. The HR24 can use one SWM coax for 2 tuner recording or 2 multiplex coax for 2 tuner recording. It's configured in the settings. Look at the coax connector labeling, one is labeled SWM.
If the RV is not SWM then you will have to change the settings when you move the receiver.
My setup was greatly simplified when both home and RV were SWM.
