time2roll
Feb 21, 2019Nomad
You checked the outdoor outlet and the fridge? Tank heaters? Any basement outlets? I assume it is an inverter/charger so no converter.
No harm to make the switch except if something is connected and it drains your battery. Worst case isolate that item or swap it back.
Yes all three (hot, neutral, ground) should be moved to the subpanel.
