steved28
Feb 21, 2019Explorer
rgatijnet1 wrote:
When you say that you moved the neutral to a different buss, what did you mean?
In a residential structure, the neutral and the ground are usually tied together in the electrical panel. With an RV, the neutral and ground are kept separate in the electrical panel.
I was surprised to see this also, there is a common bus for the ground (both main and subpanel) but separate buses for the neutral. And sure enough, if I left the neutral on the main bus, it did not work.
