steved28
Feb 21, 2019Explorer
garym114 wrote:Ivylog wrote:
You now run the risk of tripping the breakers on the inverter, a common problem in the winter when electric heaters are used on a circuit from the inverter sub-panel. Your inverter has a transfer switch which is protected by two circuit breakers hidden on it.
To add to this, your inverter passes through shore power to the subpanel. On a 2000 watt inverter this is probably limited 30 amps even though you are connected to 50 amp shore power.
This outlet would let you run a heater without taxing this 30 amp limit.
I did take this into consideration. I will be limited to a 30A subpanel breaker. But the only reason I wanted this particular outlet on the subpanel was to power PC's, tablets etc. It's the only outlet convenient to the dinette. I have other outlets at the kitchen counter to run coffee pots etc. I don't see ever running a heater, since there is an electric fireplace nearby. (which has it's own separate circuit on the main)
