NWboondocker
Mar 07, 2018Explorer
legolas wrote:
WOW, I knew I'd get good stuff thanks to all who took time to give advice. Not to appear to stupid ...just stupid enough.....I understand the definition of "tail swing" but not necessarily the actual working if that makes any sense. Perhaps someone can give me an example. I know it sounds dumb.
The most extreme case is cranking the steering wheel to the stops from a stopped position, then taking off. The back end pivots around the rear axle, leaving the body overhang to swing into whatever is adjacent (gas pump, car in next lane, etc.). You moderate it by starting to turn slowly as you pull away, then turning harder later in the turn once clear of potential obstructions.
38,782 PostsLatest Activity: Sep 10, 2026
