DrewE
Mar 09, 2018Explorer III
pnichols wrote:
Note that your excellent CCC relative to the size of your Class C is primarily due to the generous improved front axle rating of your current E450 chassis over that of earlier ones. What this means is that as you make use of your high CCC rating ... make sure it's mostly in the REAR HALF of your rig that you do it. ;)
I believe you meant to say FRONT HALF abobve.
(Adding weight in back of the rear axle will unload the front axle and transfer that additional weight to the rear one, as with any lever.)
38,782 PostsLatest Activity: Sep 10, 2026
