richy2's avatar
richy2
Explorer II
Jan 12, 2022
MPG for transit based motorhomes
We just ordered a Sunseeker TS 2370 on a Ford transit chassis. What kind of mileage can I expect with this rig? My current motorhome is a Dynamax rev on promaster 3500 and gets 15 mpg. I'm hoping to get similar mileage.
  • RetiredRealtorRick wrote:
    I might have missed it, but not a soul has asked if the Transit is a gas or diesel?? Big difference. Last I heard they still made Transit's in both versions. Am I correct?
    I don't know why, but Ford replaced the diesel engine with a turbo-charged V6 gasoline engine a year or two ago in their Transit RV-cut-away chassis. I wonder if the diesel is available on "any" chassis any longer.
  • I might have missed it, but not a soul has asked if the Transit is a gas or diesel?? Big difference. Last I heard they still made Transit's in both versions. Am I correct?
  • OK, Time to clear up the GMC/TZE things. (Look at the pic in the sigfile.)
    There is no tag axle. The statement that the rear are in tandem as opposed to dual is correct, but by definition (according SAE) that is a single rear axle as the designed (some have changed) only has the single suspension for the tandem wheels. The ride in the back is so nice that when needed, we can sleep the off watch crew. We tried that in a Class C and that is all I will say.
    GM dumped all of that business in 1978 and have not looked back, so don't ask them. The well established community of owners knows way more about it now than GM Truck and Coach ever did....
    And No, what you do at the rear has no effect of the load on the front tires.
    Could "Chrysler" pick it up and run with it? Sure they could, and they would be smart (IMHO) to do so. If/when they do, they would be smart to look at some of the re-engineering that has been done in the community. But, from the contacts I still have with that ex-employer, they are distinctly not interested. They dropped the whole RV effort when they shut down the big block line on Mound Road. That was part of the loan guarantee deal with the government.
    Matt
  • rjstractor wrote:
    ron.dittmer wrote:
    That is decent fuel economy. Too bad that chassis is offered only with a SRW axle. A DRW would have done the chassis wonders.
    I've seen this comment regarding this chassis from you before and wonder why.
    I have read a number of times on various RV forums, comments from owners of Dodge Promaster 3500 based class C motorhomes. They state that they are very limited regarding what they can carry. They are counting each pound. They can't have a 3rd passenger and never drive with fresh or waste water on-board. The basic house with all it's features, simply takes up all the weight margin.
    Having dual rear wheels in back if only to gain an extra 500 pounds of capability where it is needed, would solve much. I assume the front wheel drive engine and transmission could handle the extra weight of a duel rear axle & springs plus an extra 500 pounds. If not, then I feel the chassis is even more questionable as a cut-away.
    The class B application (a basic van) is all together different because it weighs significantly less than an outfitted class C. Being front wheel drive, there is no drive shaft or rear differential. The extra under-belly space provides outfitters with more area to utilize compared to a rear wheel drive Sprinter or Transit equivalent.
    I am no expert on these things. This is only my opinion.
  • 2112's avatar
    2112
    Explorer II
    JaxDad wrote:
    rjstractor wrote:
    RGAWR on a Promaster is well under 6000 lbs. Single rear wheels handle these weights easily.
    If you bump that up to a 7K+ RGAWR on a FWD chassis, you're not going to go anywhere SAFELY when you're fully loaded.
    Shhhhhhh. Don’t tell GM that.
    Clicky, clicky, clicky……..
    Wouldn't the rear leveling airbags push some of the weight to the steering axles similar to a tag axle?
    Not to mention the heavy 455 and transmission sitting on top of the steering axles
  • JaxDad wrote:
    If you bump that up to a 7K+ RGAWR on a FWD chassis, you're not going to go anywhere when you're fully loaded.
    Those were tandem axles, not dual rear wheels.
  • JaxDad's avatar
    JaxDad
    Explorer III
    I've seen this comment regarding this chassis from you before and wonder why. The Promaster chassis is front wheel drive, and it would be silly to put dual rear wheels on a front wheel drive chassis to load the rear axle heavier. These trucks, when their axles are fully loaded, have about a 45/55% F/R weight bias. RGAWR on a Promaster is well under 6000 lbs. Single rear wheels handle these weights easily. If you bump that up to a 7K+ RGAWR on a FWD chassis, you're not going to go anywhere when you're fully loaded.
    Now, the RWD Transit and Sprinter chassis, benefit from a DRW axle since they carry more weight in that configuration. But the DRW Transit does not have a wider rear track than the SRW, unlike your E350, so the DRW Transit will not have the extra stability a that the wider track of the E350 or 450 DRW.
  • richy2 wrote:
    My current motorhome is a Dynamax Rev on a Promaster 3500 and gets 15 mpg. I'm hoping to get similar mileage.
    Someone on the Phoenix Cruiser forum with a Phoenix TRX (2019 Transit chassis, non-EcoBoost gas engine) is reporting 11mpg, non-pampered cruising 65-72 mph, a negligible improvement from our 2007 E350 6.8L-V10 Phoenix Cruiser 2350 HERE, driving under the same conditions. We get a solid 10.5 mpg trip average, no towing, pampered 60-62mph.
  • 2016 Transit- with the wind 17 against the wind 13. Average over 3500 miles one month was 15, mostly staying within 500ft of 5000 ft elevation.
