- Executive45Explorer IIIAre you asking about the red white and blue colored rope lights or the multi colored ones that flash off and on changing colors...?////Dennis
- MeffrigExplorer
Multi colored LED's that change colors. CW sells the Dometic brand but the kits are high dollar compared to some other brands. I don't mind paying CW's price if they are really worth it. - gvisnicExplorerWhen I installed mine, I opted for an RF control versus an IR controller. This uses radio frequency versus infra red that you have to point directly to the controller. I was able to drill a hole from the outside into a cabinet, used a plastic piece like they use for running cable into the house, sealed with silicone well, and was able to tap into a 12v wire to a map light over the passenger chair. I also wired in an on off switch that lights up, lets me know the circuit is on.
- slemnahExplorerWhere are youguys getting your LED light strips?
Steve - MackteeExplorerBought mine at Avondale CW and happy with price and product. Macktee
- EffyExplorer IIThese are cool. 2 questions though. How do they attach to the coach? And seems the smallest comes in 16.4 feet. I only need 12. Can they be cut? I can't find smaller lengths. 10 feet would be ideal.
- MackteeExplorerEffy, mine came in 39inch strings that fit together and then you could cut off what wasn't needed. Macktee
- EffyExplorer II
How do they mount? Screws, adhesive? And I assume it's easier to get the kit with dimmer, power cord etc. - MackteeExplorer
They have adhesive backing. These are the ones with the RF remote, so you don't have to point it right at it, and it has a number of different dimmer settings. They are hardwired in. Macktee - EffyExplorer II
Cool. You have a link to what you bought?
38,705 PostsLatest Activity: Jan 14, 2025
