JulieB888's avatar
JulieB888
My 1992 Dometic RM2310 Fridge Stopped Working
Hello Kindly Folks,
I having serious trouble because I am full-timing and boon-docking and my propane fridge just stopped working completely. The light still comes on and stays on and it still gets really hot in the back but it won't work at all either on gas or electric. The propane light seems orange but it has always seemed orange (I've been using it for two years now without much trouble).
Now from what I read it seems that I may have damaged it by using it while the RV was un-level. However this is pretty odd because it was literally half a millimeter unlevel for 24 hours. It was just a few hairs over 4 degrees. Dometic have themselves told me that 4 degrees is still safe and i run it on 4 degrees many times without any problem. However I have also had it perform poorly after being just slightly unlevel before and it has always bounced right back after being leveled out for 12-24 hours. This time its different and I just don't understand it or are just unwilling to accept that it is permanently damaged and am hoping that there is cheaper solution out there than having to replace the whole fridge.
This bring me to my next problem. Someone old me that he pump the coolant out of it and replace it. That sounds kind of dangerous and I am not sure if I trust this person. Has anyone heard of this procedure? Is likely to help? Is it dangerous for someone who is not a professional mechanic to try and do?
Any and all input will be highly appreciated.
Thanks so much!
  • You can find a manual for dometic fridges online-
    search for:
    "newdometicrefrigeratormanual"
    even if it doesn;t cover your exact model it will help with cleaning the jet, and other simple tasks which may help such as cleaning the baffle in the stack and checking the door seals.
    from what I gather from dometic- if the coach is comfy enough for people, then it should be level enough to operate correctly.
    also I have found that added cooling fans help the fridge cool greatly.
    my many experiments in August showed that I can expect cooling of 55º below ambient temps
    Mike
  • Never heard of anyone pumping the coolant out of it and replacing it - sounds kind of sketchy. The problem is that sediment from the tubes corroding from the inside settles in the bottom and the coolant can no longer circulate. I can see how pumping out the old stuff, and maybe some sort of flush, could help but I've never heard it being done in the field so-to-speak. You can buy refurbished cooling units but I don't know what to what extent the old tubing is used. My 31-year-old Norcold has a refurbished cooling unit in it and it works great.
    I would either look at replacing the fridge completely or replacing the cooling unit.
  • Coolant is a mixture of ammonia, sodium chlorate/water (rust inhibitor) and hydrogen gas under 300 psi.
    Even professionals don't recharge ....complete rebuild of cooling unit YES but not just recharge
    When operated off level (even points as little as 20 mins) the cooling unit can overheat which causes the sodium chlorate to foam crystals that attach to inside of tubing. This is like a 'plaque' that can build up (kinda like old galvanized water pipe). It is permanent and accumulative....so over time all those periods of off level operation build up enough to block coolant flow/process. DEATH!
    That propane flame..........orange. That is NOT proper color and does not generate enough heat so that the correct amount of heat can be transferred to make cooling unit function.
    The heat has to be sufficient enough to cause the ammonia to boil/turn to vapor so it can condenser into cold liquid and absorb the heat from freezer/food section.
    SO.......
    Clean up that burner area. Clean orifice with alcohol, clean out burner tube, clean flue and flue baffle.
    Adjust flame so that it is BLUE
    Have you been running it with thermostat turned up close to MAX setting......or even tried it on MAX (full out continuous operation)?
    There is also a filter on inlet to thermostat....if clogged it will resist gas flow.
    HERE is service manual that will help you out.
