FIRE_UP
Oct 10, 2013Explorer
Spizzer wrote:FIRE UP wrote:
.......... and, into the transfer/lift pump. From that point on, it took over the ability to acquire fuel on its own. So, that's how I got mine running after doing exactly what you did. Here's some pictures of before and after, of my remedy for it to NEVER HAPPEN AGAIN. Good luck.
Scott
Scott,
Excellent idea on the valves. Did you put anything on the threads? I don't know if you should or not with diesel fuel.
Jeff
Jeff,
Well Sir, to answer your question, yep I did add Teflon tape to the threads. The reason you don't see any is because I removed the excess so the job would look better. Not sure who would care but, I thought it would just look nicer without a ton of excess tape hanging around.
Scott
