tropical36
Aug 26, 2018Explorer II
RVER wrote:
Tropical36 if you take a look at your owners manual it says NEVER lift the tires off the ground with the levelers, Front levelers can fail and when that happens the rig would slam to the ground and move forward and can conceivably kill someone. THEY are not that strong. YOU cAn level with wood and then stabilize with the levelers so you can be level. I have been on sites that it takes time to get it level but never will the tires be off the ground. I carry wood with me to drive up on if need be with very unlevel site.
Never said to be crawling around under there and when I use the jacks to raise for working, I always set a floor jack in there, as well.
Tell me though and when have you ever heard of a coach come slamming down to the ground, with a jack failure? Maybe a slow and leaking down process, but slamming down and not leaving any appreciable ground clearance, next to never, but then I've never been one to say never.
There's a lot of campgrounds in America alone and there's thousands upon thousands of coaches with their front wheels in the air, as we speak. As for strength, they're plenty strong and will hold a lot more than the coach, if truth be told and just as long as a hose doesn't burst. They have to be, cuz in terms of liability, misuse of a product, is indeed, the use of a product.
