atsrmf
Aug 26, 2018Explorer
Be sure to take a pressure reading at each bleeder valve after flushing the fluid. This will tell you if the system is working properly and is balanced as designed, you should get around 1200 PSI as an example. It is similar to taking a voltage check at a panel. Replacing the wire may not solve the problem!
