Black95
Jun 06, 2017Explorer II
Most of the modifications I make now are more like fine tuning my van as we are using it now. Every once in awhile I find something new that helps make life easier in our van. This is one of those. I had my dash cam connected through a 12 volt adapter, but this new adapter lets me plug my dash cam directly into a USB port type charger. One less adapter to mess with. I hid the dash cam cord behind the trim around the windshield and under the trim on the front of the door opening trim to keep it out of sight.
Another accessory plug that I have added under the dash on the passenger side.
When mechanics work on my van's engine they have to remove the console and the "doghouse." I added a quick disconnect plug to the wires supplying voltage to the accessory plugs so the mechanic can quickly disconnect them without having to cut wires. The white plug can be easily seen in this shot but I normally have it behind the trim out of sight.
38,769 PostsLatest Activity: Dec 31, 2014
