ron_dittmer
Jun 16, 2018Explorer III
Hi Claybe,
I can't comment on the noise, but I can share our experience with our 2007 Ford E350 chassis motor home.
Brand new, the rig handled like a drunken sailor. Later that same year in 2007, I took the rig to our local truck/RV suspension shop. $3900 later and the rig handles like an SUV. What a huge difference, well worth the cost for handling & safety, comfort for all, and greatly reduces driver fatigue. Champion Frame Align in Elgin IL did the following.
- Added a rear Roadmaster heavy duty stabilizer bar (the E350 lacks one through year 2007)
- Replaced the wimpy stock front stabilizer bar with a Roadmaster heavy duty version.
- added a rear trac bar (was recommended because we tow another vehicle)
- replaced the stock shock absorbers with heavy duty versions
- replaced the wimpy stock steering stabilizer with a heavy duty Safe-T-Plus version
- did a front wheel alignment (was off so bad they installed offset bushings to get it right)
- determined the proper tire pressure. (make sure your tire gauge reads accurately)
That was 11 years ago. We have enjoyed driving our rig ever since. Our replacement shocks were the red adjustable Koni-RV (set to heavy-duty) but they went bad recently. I am replacing them this month with Bilstein heavy duty RV shocks.
Each motor home has it's own characteristics due to the differences in size, shape/aerodynamics, adjusted wheel base, load, and the distribution of the load. So what works well for one motor home might not be necessary for another. I advise to weigh your rig to determine the right tire pressure, and also a good wheel alignment (done so as it will be loaded for a trip) and the heavy duty front and rear Helwig stabilizer bars. That would a great start. I do think you will also end up investing in a heavy duty steering stabilizer. If you want to cover all your basis up front with best results, then do as we had done. You can't go wrong that way.
