holstein13
Jun 17, 2014Explorer II
Executive wrote:
Now that you've fixed the fins...get a big bag of zip ties and go through the coach and zip tie the wiring about every 12-18". That will keep them from moving around while the coach is moving. Bending the wiring will eventually lead to the wiring failing...the zip ties will prevent the wires from being bent back and forth due to the movement of the coach.....Dennis
I think Dennis is just messing with you. Wiring harnesses are always zip tied to begin with. It would have to be a pretty bad coach to have loose wiring in it.
