Harvard
Jul 11, 2013Explorer
j-d wrote:
That high caster number is impressive. How'd they get it that high? I'd heard that high caster tends to take camber out of the spec range.
Also, what do you have for a toad. I sometimes think the caster settings on a toad may explain why some toads do not adhere well to being a toad. They may have "a mind of their own" and want to go in a straight line more then others might. Just a thought. On the other hand, if a toad has little caster then they might also want to wander around causing discomfort to the towing vehicle.
For example we tow a 2007 Honda Civic with +7.0 Degrees of Caster but only a total of 3000 pounds of "authority". :B
On edit, the Honda caster is fixed at +7.0 and not the +6.0 in my original post.
