calfman47ExplorerSep 16, 2013My headlights went out lowbeams and highbeams.Both high and low beams just went out all my other lights work fine. I cut the wires to the low high bulbs and added a switch and fuse and they are working now while i have them on seperet circits. ...Show More
eHoeflerExplorer IISep 16, 2013Did you check the fuse?? Also, check the headlight switch and the dimmer switch.
Related ContentHow to adjust LED headlights?Sensitive headlight sensorWeak headlightsHeadlights Went OutFoggy headlights
