NTORACN wrote:
You should look into getting a Scangauge setup. It allows you to monitor all info available on the OBDII port connector below the dash. My older unit can monitor up to four items at one time. I like to keep an eye on engine RPM, water temp, intake air temp (basically outside air temp) and throttle angle. How about hooking the back light into the dash light for dimming purposes? I know its a little more work, but it would allow you to manually tone the brightness down with the dimmer switch or just add a resistor to the offending light?
X2 on the Scangauge. I have an Ultragauge and love having all the info available.
