Got a few things done this morning....
Had the Tireman Extended Valve Stems installed by Discount Tire on all 6 wheels today.
Cost- $60. Satisfaction knowing that checking the tire pressure is super simple now - PRICELESS.
Here's the rear without the simulator installed-
I had to tweak the outer stem a bit with a piece of tubing (under the direction of the Tireman himself) -
The font-
I also installed a GFCI outlet & all weather cover on the outside today. Unbelievably, the outside outlets were unprotected. Good to go now-
