carringb
Aug 02, 2013Explorer
darealmccoy wrote:
My Concord came with a spare as standard equipment. It is in a well in the rear compartment made for that purpose with a lid on the well. But, as Bumpy says, no jack or lug wrench. I would not attempt to change a tire - that's what I pay Coachnet for.
One poster mentioned removing a rear dual to use in the event of a front tire flat. Not a good idea, even if it would fit - with aluminum wheels, only the inner steel OEM wheel will work up front - as you will grossly overload the remaining tire, quite possible causing it to blow. Just my $0.02.
Dave
Ford or Alcoa Aluminum wheels can be used in any position. Only difference between them is which side is polished, and you can't run 2 together because the stock studs are not long enough.
38,769 PostsLatest Activity: Apr 24, 2002
