sealevel_ram
May 28, 2014Explorer
rcmiller32 wrote:
100 psi sounds a little low for your max air pressure. should be in the 120 to 130 range. can take 90-100 psi just to compress the parking brake spring. sounds like the governor is bad.
I should have said it goes OVER 100 psi. I will look and see how much over and try to adjust if necessary.
I did have a repair done on my air system a couple of months ago. Maybe they messed up the max pressure setting.
