Big_Blue's avatar
Big_Blue
My RVs Primitive Brain
Background: 2008 Winebago Destination. 340 Cummings ISB 6.7L diesel. 27k mileage.
We are in our third season on this chassis/coach and it has been a sturdy chariot to places familiar and new. One nuisance has been the occasional check engine light. Usually associated with cumulative turbulent road conditions. The first one ever was for coolant level. Pulled over, checked, all was well, and trip continued. Other times, the alarm would occur and eventually clear.
I have been very reliable about checking the oil, coolant and dumping out the fuel/water filter, along with purging the compressed air after each trip.
This past trip started with two days of traveling over 750 miles. Then a week on the ground with no coach/chassis movement. First day on the return trip was stable, until the last several miles, several check engine lights that self cleared. The following morning, dumped some more out of the fuel/water filter with the hope that this would resolve the check engine light warning. Then it got worse, on the final day out, while going up a modest hill, the check engine light came on, then the flashing red STOP ENGINE light came on. We immediately pulled off into the breakdown lane, and as we came to a stop, the ENGINE STOPPED.
Rechecked the three of the four causes - oil level, coolant level and the ensured the fuel/water filter was in good condition. This left the final cause ~ the dreaded, unspecified something else. Corrective action, get thyself towed to next Freightliner chassis service facility. This was 25 miles always, in Maine, and did I mention that we were in New Brunswick.
Good Sams Emergency Roadside Service activated. By the way, did I mention it was Sunday morning? GS coordinated a tow truck response with a tow to the next capable campground for the overnight. The next day, we were to call again and coordinate a tow to the next authorized service facility.
Tow truck guy shows up. Checks the several things I already checked. That's okay, experienced second opinions are welcome and in this case conformational. Engine restarted, all readings nominal. Plan was to continue up the road and monitor for Stop Engine recurrence. The Check Engine came on for a breath taking good 15 seconds. Then went off, stayed off, we parted ways and there were no further issues on the rest of the way home.
Next step, get the chassis/coach to the local Freightliner service facility for review. I'm thinking a failing sensor? Wonder if it would be worthy replacing the suspect sensors?
Your thoughts?
