SCVJeff
Aug 04, 2015Explorer
Spizzer wrote:It changes a LOT, thats why I was curious. I'm about a 35, but to set that pressure with not laying on it, that jumps to 50+. If both sides are set to 35, and I'm there by myself, I need to run the other side up at least to 50 to keep from rolling into a hole.SCVJeff wrote:
I'm curious what your weighted (with you on it) sleep number is? Doesn't sound like there's allot of headroom.
Unfortunately, there is no way to read what the pressure is. You can only see what it was last set at. If you change the pressure, say down one click, then up one click to where it was, the controller senses the pressure and then changes it to the setting. So if it does nothing, it was spot on...if it lets air out, it was over the setting, if it pumps air in, it was under the setting. I don't think it changes much when you lay on it.
jeff
35 is safe where we usually travel, but pushing the 'empty' side up around 60'ish while at the beach can make for a very bulbous mattress when heading home in the summer
