Bikeboy57
Aug 31, 2018Explorer
Ok. That is good news. One more check to rule out internal engine damage. Drain a pint or so of oil into a clear jar. Let it sit. If there is coolant in the oil, it will settle to the bottom of the jar and will be visible. If you have any coolant in the oil do not run the engine. Coolant in thr oil will cause the bearings to seize.
38,769 PostsLatest Activity: Apr 03, 2026
