dougrainer
Jun 22, 2014Nomad
1. Just reset with the Magnet
2. Norcold will NOT send any recall parts to a retail customer---PERIOD!
3. You must go to a Norcold service center to have any type recall work done or replaced other than the Magnet reset. Remember, your unit may have tripped because you DO have a defective cooling unit
4. If the refer was NOT on and you have a large amount of water and no rain, then the Icemaker supply system is the suspect. NOT from the icemaker water valve to the icemaker mold as it will not be there since the refer was off. Do a complete trace from the icemaker water valve feed to the supply in the RV. You will probably fond that pinhole. There will be NO drain type problem as the refer was NOT ON. Doug
