RayChez
Jun 22, 2014Explorer
Sometimes the rubber hose from the refrigerator that extends to the outside is plugged up. I noticed a few years back water coming from the frig. It was coming from the tray under the fins on the inside back of the refrigerator and why it was full was because the hose was plugged up where it drains into the small cup on the out side. I just got an ice pick and poked it where the small hole is suppose to be on the end of the hose, and water squirted out right away to also help drain the inside tray. So my suggestion is to poke the end of the rubber hose and let it drain IF that is the problem.
Other then that I would say Heisenberg has a good point on his post. It could be a flex hose.
