ChristineMarie's avatar
Dec 13, 2013
Navion ceiling adhesive pattern
We have a friend with an 09 Navion... you can see what looks like adhesive staining through the interior ceiling fabric. The exterior roof shows no problems and seams are good. Pattern follows exactly the ductwork of the air conditioner. Has anyone run into this? Thanks in advance for any assistance.
Chris
  • Haven't experienced this personally, but did a little Googling. Since you mentioned the AC vents, could it be a result of thermophoresis, rather than the adhesive showing through, or (shudder) a hidden leak?
    Thermophoresis–Soot deposits will often form patterns that correspond to the framing in
    walls and ceilings, or will accumulate near sites of air movement, such as around HVAC
    registers. The formation of such patterns is driven by temperature differences, and is
    called “thermophoresis.” Suspended particles such as soot will move "down" a
    temperature gradient. A temperature gradient is a declining temperature in one direction
    through the air. A temperature gradient will occur across the surface of walls, where the wall area over the more thermally conductive framing is typically slightly cooler, during
    cold weather, than the surrounding wall. It will also occur between the warm air leaving
    a heating system register and the cooler wall nearby.. . .
    From this link.
    This causes the "filtration lines" or "filtration soiling", in the lingo of professional carpet cleaners, that frequently occur on carpeted surfaces along baseboards and under infrequently used doors etc. It can be called "ghosting" if it occurs on home walls and ceilings, where the structural elements become apparent. It is apparently quite difficult to clean.
  • May I suggest you move this to class C forum where you can get the proper answers. Your friends rig is made like a class C so you will get more experienced help there. Good luck.
