Whaler
Sep 26, 2013Explorer
Need 12V Chassis Air Conditioner Fan Replacement Info
The fan motor on my HVAC chassis fan locked up. This is on a Spartan Summit chassis and is located just above the front axle. The fan cools the AC coils for the dash air. I called Spartan but was told that the coach manufacture supplies this unit. Since National RV is no longer in business I am out of luck there. I am looking for other Coaches on the same chassis that are still in business that might use a compatible motor. I cannot get the fan off of the motor due to corrosion and the numbers I need must be under the bracket where I cannot see them. Any help would be appreciated.
