Old-Biscuit
Aug 16, 2014Explorer III
Is the LED on panel 'ON' or blinking? How many times?
Open a faucet.....flow switch makes up. Circuit board goes thru a self check and then blower comes on. Sail switch has to CLOSE then DC power goes to gas valve and ignitor.
If 'high limit switch' is OPEN (167*F) no power to circuit board for gas valve/ignition
If 'ECO' is OPEN (131*F.....Closes 110*F) no power to circuit board for gas valve/ignition
If 'Sail Switch' doesn't CLOSE no power to circuit board for gas valve/ignition
LED ON or blinking.......??
Error codes:
•Steady On-Internal Control Fault (Circuit Board)
•1 Flash-Air Fault (Sail Switch)
•2 Flashes-Flame Detection Error (No main flame detected)
•3 Flashes–Lockout (Ignition/main flame failure)
•4 Intentionally ‘NA’–Reserved for Future Diagnostics
•5 Flashes-Low voltage
Error codes:
38,780 PostsLatest Activity: Jul 04, 2015
