Old-Biscuit
Oct 10, 2017Explorer III
Crabbypatty wrote:
I will service that with those suggestions. Mine takes two cycles to light. It lights off then stops, 3x then red fault light comes on. I turn it off for a minute, then usually by the third automatic try it stays lit. It lights almost every time but just wont stay lit.
Sparks----flame lights....then no flame
That is due to 'flame lit' signal (milliamp generated by flame lighting) is NOT getting back to circuit board via the spark electrode/wire.
Spark electrode:
*Clean with emery cloth to remove any carbon/soot
*Needs to be engulfed in flame when it lights off
*Clean/tighten high tension wire connections
*Assembly mounting screw needs to have clean/tight connection for proper ground
*Ceramic insulator...no cracks
