udidwht's avatar
udidwht
Need genrator help?
FYI....
For anyone in the Seattle area we have a great generator tech named Chuck. He's in Auburn, Wa. He agreed to come out to me (Renton-Highlands) and diagnose my Onan Microquiet 4K which would only run if I hold the start button.
I initially checked with a volt meter some pins and narrowed the issue down to either a bad control board or voltage regulator. When Chuck showed up he threw his Flight Systems G-Man 360 on it and within 5 min bingo...bad voltage regulator.
The voltage regulator that was on it had been replaced back in 7/11 with a Flight Systems 305. I was leaning at it being a bad control board.
  • Ya, he's not as great as you think. He "fixed" ours, we went on vacation, it went out, and my other died of heat exhaustion on the way home. True fact.
    • MNtundraRet's avatar
      MNtundraRet
      Navigator
      We could use more information here. Your "Other What" If you are knocking a company, you should give us more information on what you call fact.
