Horizon170
Apr 29, 2014Explorer
Sea Dog wrote:kaydeejay wrote:
Why not simply add an external pump (mounted to the frame rail)? It will draw through the dead in-tank one.
Indeed.
Much less expensive way to go.
Make sure, if you do go with the inline pump,
that it is specifically for carb or EFI
depending on which you have.
Fuel pump and fuel gauge are the same unit. It is probably a rotted hose from pump to outside of tank and not the pump. If so the pump is pumping gas back into the tank.
Carquest has the pump or can get one. I would never take a '91 to a Dealer because they will nail you with high prices.
38,769 PostsLatest Activity: Apr 03, 2026
